Lock control anti-theft alarm circuit diagram
Source: InternetPublisher:newrudeman Keywords: Alarm control Updated: 2021/07/19
As shown in the figure is the lock control anti-theft alarm circuit. The circuit consists of RS flip-flop, gated oscillator, alarm circuit, etc. The RS flip-flop is composed of NAND gates F2 and F3, and the gated oscillator is composed of integrated circuit TWH8751 and R and C.
When SKK is in the "lock door" position, input terminal 2 of NAND gate F1 is high level, and F1 directly reflects the status of DBK1-n. If one of DBK1-n is open, F1 outputs low level. Set the RS flip-flop to "1" (Q is high level, Q is not low level), the corresponding strobe pin ② of TWH8751 is low level, triggering the oscillator to start oscillating, and the oscillation signal causes the speaker to sound an alarm.
When SKK is in the "open" position (that is, using the key to open the door lock normally), the input terminal pin ② of F1 is low level, so the input terminal of F1 is blocked and the RS flip-flop is reset (Q is low level, Q is not high level), correspondingly TWH8751 will not oscillate because the strobe pin ② is high level, and the alarm will not work. At this time, the owner can use all the items monitored by DBK1-n at will. When the owner locks the door and leaves, the alarm will automatically resume normal operation. When extinguishing the alarm, first use the key to unlock the door and then press AN.
- Circuit diagram of game score display using 7-segment LED
- Measurement and analysis of automatic emergency lighting circuit
- IRS2530D electronic ballast circuit diagram
- Use NE555 to make a touch self-extinguishing table lamp
- One of the water full alarm circuits
- Lighting sound-activated switch circuit using thyristors Part 3
- Two-way electronic music doorbell circuit
- Fluorescent lamp dimming circuit composed of thyristors
- Photoelectric adjustment circuit
- Simple sensor alarm
- Motorcycle anti-theft alarm circuit diagram
- Simple and practical electric vehicle anti-theft alarm circuit diagram
- Circuit diagram of miniature wireless alarm transmitter
- Circuit diagram of low voltage disconnection alarm
- Grid disconnection alarm circuit diagram
- Lock control anti-theft alarm circuit diagram
- Homemade motorcycle anti-theft alarm horn circuit diagram
- Normally closed contact anti-theft alarm circuit diagram
- Wearable medical device voice alarm circuit diagram
- Circuit diagram of disconnection alarm composed of 555
