Circuit diagram of disconnection alarm composed of 555
Source: InternetPublisher:ghaytweyhtoo Keywords: 555 alarm control disconnection alarm Updated: 2021/12/11
1. Purpose of production
The alarm sounds when someone breaks in illegally
2. Circuit design and production analysis
①.Circuit schematic diagram
②. Principle analysis
The core part of the circuit is composed of NE555. R1, R2, C1 and NE555 form a multivibrator circuit with a frequency of about 3KHz. When the circuit is powered on, the oscillator starts to work and the buzzer LS1 sounds; when 1 and 2 When short-circuited, the operating conditions of the oscillator are destroyed and LS1 stops working.
③、Circuit analysis
When the power is turned on, if the control switch is closed or the moving contact contacts the static contact, the alarm is in standby state;
When the control switch is open, the door opens and the alarm sounds; (on the contrary) the ideal working voltage of the alarm is 9V. When the working voltage is 9V, the standby current is about 3mA and the working current is about 8mA.
④. How to use
As shown in the schematic diagram, fix the movable contact piece on the door, fix the static contact piece on the door frame above the door, connect the two movable contact pieces to 1 and 2, and place the control switch in a relatively hidden place. When the owner opens the door First close the switch to disable the alarm function and the alarm will not work; when leaving, turn off the switch to restore the alarm function.
3. Production verification
When the circuit is powered on, turn off the control switch and 1, 2, the alarm will work; close the control switch or 1, 2, the alarm will stop working.
- Low cost LED automatic emergency light circuit
- Electronic massage and acupuncture device circuit
- Low illumination amplifier circuit
- Infrared remote control device circuit
- Application circuit of CAT3606
- Chandelier brightness controller circuit using thyristor
- Large light emitting diode display circuit
- Incandescent lamp dimming circuit using thyristor part 4a
- Fluorescent lamp dimming circuit composed of thyristors
- Bedside lamp controller circuit
- 555 time base fully automatic fast charging circuit diagram
- Road ice alarm circuit diagram
- Motorcycle anti-theft alarm circuit diagram
- Circuit diagram of miniature wireless alarm transmitter
- Circuit diagram of low voltage disconnection alarm
- Rain alarm principle circuit diagram
- Grid disconnection alarm circuit diagram
- Lock control anti-theft alarm circuit diagram
- Simple and practical elevator power outage alarm circuit diagram
- Wearable medical device voice alarm circuit diagram
