LED detector
Source: InternetPublisher:清宁时光 Updated: 2012/12/17
This tester can detect the polarity of light-emitting diodes to determine their luminous performance. In batch testing, compared with testing methods such as multimeters, it saves time, effort, and is simple and intuitive. The circuit is as shown in the figure below. One operational amplifier is connected to a low-frequency self-excited oscillator, which intermittently outputs high level or low level at the output end. The other op amp is connected in the form of an inverter. When the oscillation circuit outputs a high level, the inverter outputs a low level; when the oscillation circuit outputs a low level, the inverter outputs a high level. If a light-emitting diode is connected across the two output ends, regardless of the polarity of the jumper, the light-emitting diode will always turn on and emit light intermittently according to the oscillation frequency of the oscillation circuit. LED is a power indicator tube and also serves as a comparison tube for luminous intensity. The op amp IC can be LM358 or LM324.
![发光二极管检测器](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/d0740576-3c63-11ec-b1f8-086126841eb8.jpg)
Latest Detection Circuits Circuits
- Simple and easy to make zero degree detector
- DIY Multimeter High Frequency Signal Probe
- Design of wireless meter reading system based on DSP
- Simple infrared detector
- Fire detector made with photodiode
- TC02 temperature measurement circuit
- Use LM3915 to make a practical audio power meter
- direct coupled amplifier circuit
- Light Detection 4 to 20mA Current Transmitter Circuit
- Typical two-stage low-pass filter circuit
Popular Circuits
- LED lighting display detection circuit with overload protection
- Paper thickness detection circuit
- Pyrothermal infrared detection circuit composed of OPA111
- Simple infrared detection circuit
- Level detection circuit using digital-to-analog converter
- A5348 smoke alarm detection circuit - block diagram
- Photodetection circuit for DC recovery to suppress unwanted stable background light
- Differential light detection circuit
- Film thickness detection circuit using eddy current method
- Thin object presence/absence detection circuit
