AC and DC darkroom safety lights
Source: InternetPublisher:蓝猫淘气 Updated: 2010/01/21
This darkroom AC and DC dual-purpose lamp has a contactless automatic transfer switch function. Uses orange light-emitting diodes.
During normal power supply, AC 220 volts is rectified by bridge type of transformer, filtered by capacitor, and outputs about 4V DC (5V when no load). Because the battery voltage inside the machine is 3V, diode D is turned on, and the light-emitting diodes are powered by the rectified power supply. Since the BG emitter potential is lower than the base potential, BG is turned off, and the battery E in the machine is automatically turned off, and there is no current output. During a power outage, the BG emitter potential is higher than the base potential and is in a conductive state. Battery E supplies power to the light-emitting diode via BG. If the mains power is restored, diode D will be turned on again and BG will be automatically cut off.
Latest Control Circuits Circuits
- Design and selection of electric control valve system drive
- Model rocket launch controller circuit
- Design of an autonomous plant watering system using ATtiny85
- How to build a simple tachometer using an infrared reflectance sensor
- Tutorial for building a remote-controlled Arduino Air-Boat
- An automated model railroad layout project using a microcontroller
- Do-it-yourself trial production of phase failure protection device
- Design and production of no-load automatic power-off device for household power supply
- Delay switch made with LM431
- Homemade short circuit alarm device
Popular Circuits
- Multi-channel patrol detection control circuit a
- Water and electricity saving infrared control circuit
- Photocell amplification control circuit
- Switching regulated power supply circuit
- Assembly line outage monitoring circuit
- sound control circuit
- Relay control circuit a
- Temperature measurement and control circuit
- Typical electronic volume control circuit
- Small signal to large current photoelectric control circuit
