Motorcycle brake light delay turn-off circuit
Source: InternetPublisher:toothache Updated: 2017/09/21
When a fast-moving motorcycle encounters an unexpected situation or needs to turn, it needs to use the foot brake to slow down or stop the vehicle. Generally, the brake light on a motorcycle will come on after the foot brake is applied. Once the brake is reset, the brake light will go out. In this way , it is not easy to attract the attention of vehicles behind. If this circuit is installed on a motorcycle, the motorcycle brake light can be delayed for a few seconds after the brake is reset like a car light to remind the following vehicles to pay attention. This has practical significance for traffic safety and reducing traffic accidents. . The circuit principle is as shown in the figure: S1 is the power switch, controlled by the car lock, and S2 is the original brake light control switch. Close switch S1. Since the voltage at both ends of capacitor C1 cannot change suddenly, pin ② of the IC is at low level and the brake light H lights up. After a few seconds, because C1 is discharged, when the voltage of pin ② of the IC is higher than 1.6V, the light H goes out. When a moving motorcycle encounters a situation and decelerates or stops, the switch S2 is closed to short-circuit the two ends of C1 and discharge, causing the ② pin of the switch IC to become low level, and the brake light H is lit immediately. After S2 is reset, H must It will turn off after a few seconds of delay.
The IC in the circuit is a high-power switch integrated circuit TWH8752. The maximum allowable current is 4A. H is the rear brake light. R1 is 470K. C1 uses a 16V, 47μF electrolytic capacitor. C2 uses a 25V, 2200μF electrolytic capacitor. VD1 uses a 1N5408 rectifier. diode. If you need to change the delay time, you can change the values of R1 and C1 appropriately.
![摩托车刹车灯延时熄灯电路](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/d12aadf4-3c63-11ec-941b-086126841eb8.jpg)
Latest Control Circuits Circuits
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Model rocket launch controller circuit
- Build a glove-controlled robotic arm
- Tutorial for building a remote-controlled Arduino Air-Boat
- What are the challenges in designing a permanent magnet linear generator?
- A small improvement on the ordinary refrigerator motor starting circuit
- Squirrel cage asynchronous motor reverse braking control circuit
- Motor self-starting circuit
- One-way rotation circuit of motor controlled by contactor
- Design and analysis of wire control circuit
Popular Circuits
- Multi-channel patrol detection control circuit a
- Water and electricity saving infrared control circuit
- Photocell amplification control circuit
- Switching regulated power supply circuit
- Assembly line outage monitoring circuit
- sound control circuit
- Relay control circuit a
- Temperature measurement and control circuit
- Typical electronic volume control circuit
- Small signal to large current photoelectric control circuit
