Refrigerator automatic protector
Source: InternetPublisher:常思一二 Updated: 2012/06/04
The circuit is shown in the figure below, BT33 forms a delay circuit. When the power is first turned on, relay J1 does not work and contact J1-2 is disconnected. After five minutes, due to the increase in the charging voltage of capacitor C1, BT33 is turned on, relay J1 is closed, contact J1-2 is closed, and the refrigerator is powered on. , and is self-protected by the J1-1 normally open contact. Under normal voltage conditions, D2 and BG2 are on and D3, D4 and BG3 are off, so relay J2 does not work. When an overvoltage occurs, the voltage regulator tube D4 breaks down and conducts, BG3 conducts at the same time, the relay J2 is closed, the contact J2-1 is disconnected, the relay J1 is de-energized and released, and the refrigerator is powered off, which plays a role in protecting the refrigerator. When the power supply voltage is lower than the allowable value of the refrigerator (180V), D2 and BG2 will change from conduction to cutoff. The collector voltage of BG2 rises, causing D3 and BG3 to conduct, and the relay J2 will close, which will also cause the refrigerator to malfunction. Power outage.
![电冰箱自动保护器](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/d15e1ac2-3c63-11ec-b5dd-086126841eb8.jpg)
Latest Control Circuits Circuits
- Analysis of the working principle of the sound and light controlled delay switch circuit
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- A simple door handle touch alarm circuit
- An automated model railroad layout project using a microcontroller
- What is a RADAX motor?
- DC motor drive circuit composed of L293D
- Design and principle analysis of practical electric curtain remote control device
- Design and production of radio remote control fan stepless speed regulator
- Homemade anti-theft watchdog
Popular Circuits
- fire smoke control circuit
- Mobile phone camera flash control circuit
- Switching regulated power supply circuit
- Water dispenser double sheet control circuit
- Assembly line outage monitoring circuit
- 24h automatic switching capacitor control circuit
- Digital current loop control circuit
- Relay control circuitb
- Forward and reverse control circuit of micro DC motor a
- Power supply circuit with multiple outputs (MAX1902)
