Home >
Power Circuits >AC Regulated Power Pupply > Analysis of Dual Relay 100~200W Fully Automatic Voltage Stabilizer
Source: InternetPublisher:石榴姐 Updated: 2018/12/26
Circuit principle: The grid power supply is connected to pin 3 of transformer B through the switch and the normally closed contact of J1. R1 is the sampling resistor, BG1 and BG2 form a control circuit, and the starting control point can be changed by adjusting W.
When the grid voltage is lower than 220V, the normally closed point of J1 causes transformer B to form a boost mode. The output voltage does not exceed 220V, J2 is normally closed and connects pin 5 of the transformer. If it is higher than 220V, J2 is connected to pin 4 of the transformer. When the grid voltage is higher than 220V, R1 is used to sample, control J1 to pull in, and connect to pin 5 of the transformer to form a step-down type. If the voltage at the output terminal exceeds the set value, R4 sampling is used to control the pull-in of J2, and the normally open contact is connected to pin 4 of the transformer. Component selection: The power of the voltage stabilizer mainly depends on the cross-section of the transformer core and the diameter of the enameled wire. The iron core is 19× (24~25), and the coil is 0.27~0.35 high-strength enameled wire for dense winding. No paper is needed between layers. Wind 48 turns around 1~2, 822 turns around 2~3, switch to 0.41~0.51 enameled wire from the third leg onwards, and wind 85 turns around 3~4, 4~5 each. BG1 and BG3 use 3DG low-power tubes, and BG2 and BG4 use PNP silicon medium-power tubes. There are no special requirements for resistors and capacitors.
![双继电器100~200W全自动稳压器剖析](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/d1e3a066-3c63-11ec-be56-086126841eb8.jpg)
Latest Power Circuits Circuits
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- Introduction and principle analysis of switching regulated power supply
- What kind of circuit is a voltage regulator circuit?
- Single-power supply circuit for ISO122P/ISO124
- Switching power supply circuit composition and function introduction of each part
- Current/voltage conversion circuit using current converter
- Miniature polarity reversal power supply using MAX1721
- Dual forward converter schematic diagram
- A novel and practical DC low voltage stabilized power supply
- MIC4680 constant current charger
Popular Circuits
- Excellent performance household inverter power supply circuit
- Output 12V-10A power supply circuit
- Single phase thyristor slotless nickel plated power circuit
- Warm current power circuit a
- Household emergency power circuit 02
- Common power circuits and applications 08
- Common power circuits and applications 03
- DC-DC conversion power supply circuit
- ±5V, ±12V power circuit A
