Simple motor speed regulator
Source: InternetPublisher:宋元浩 Updated: 2011/09/09
Although the speed regulator introduced in this article is very simple, it can accurately adjust the speed of a motor whose operating current does not exceed 1A. As shown in the figure below, NE555 is used as an oscillator, and the pulse frequency of its output (pin 3) can be adjusted in the range of 5-12Hz. The adjustment range depends on the values of R1 and C1. Transistors T1 and T2 form a power output stage to control the motor.
AJ1 and P1 can control the 555's oscillation frequency. There are two modes to choose from: "speed adjustment" and "variable speed". "Speed regulation" mode is to set P1 to a certain frequency and let the motor rotate at a certain speed. The "variable speed" mode uses automatic control means to continuously adjust P1 so that the motor changes speed at any time.
![简易马达调速器](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/d221e2d2-3c63-11ec-9446-086126841eb8.jpg)
Latest Control Circuits Circuits
- Design and selection of electric control valve system drive
- Servo motor pin diagram/working principle/application
- Build a Smart Garage Door Opener Using a Raspberry Pi
- How to make a wheeled self-balancing robot using ultrasonic sensors
- What is a RADAX motor?
- Perform surgery on the speaker protection circuit
- Using P110C to control 6 DC motors simultaneously
- Audio interface protection circuit
- Homemade short circuit alarm device
- Ultra-short wave item left behind reminder alarm
Popular Circuits
- fire smoke control circuit
- Mobile phone camera flash control circuit
- Switching regulated power supply circuit
- Water dispenser double sheet control circuit
- Assembly line outage monitoring circuit
- 24h automatic switching capacitor control circuit
- Digital current loop control circuit
- Relay control circuitb
- Forward and reverse control circuit of micro DC motor a
- Power supply circuit with multiple outputs (MAX1902)
