Obtaining two voltages from one rectifier circuit
Source: InternetPublisher:3228 Updated: 2018/06/28
18. Obtaining two voltages from a rectifier circuit It is difficult to output two voltages from a rectifier circuit or an untapped secondary winding of a transformer, but in some cases it is precisely necessary to do so. The circuit shown in the figure below can output two voltages.
One voltage is a bridge rectifier circuit composed of rectifier diodes V1-V4, which outputs voltage U on capacitor C1; the other outputs a voltage that is twice U, or 2U, on capacitor C3. How can I output 2U on capacitor C3? The voltage doubling rectification process is: in the positive half cycle of the alternating current, terminal A of the secondary winding of the transformer is positive and terminal B is negative, and the current charges the capacitor C2 through the rectifier diode V5; in the negative half cycle, terminal B is positive and terminal A is negative. Negative, -U and U are superimposed to charge the capacitor C3 through the rectifier diode V6. Through the common ground terminal, the diode V1 to the A terminal form a closed loop. Repeatedly, a DC voltage of 2U is output on the capacitor C3.
Latest Power Circuits Circuits
- How to Make a Soft Latch Circuit
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Parallel DC regulated power supply circuit diagram
- Dual forward converter schematic diagram
- A small and easy-to-make fast charger
- Integrated regulated power supply with continuously adjustable output voltage
- Production of backup power supply for cordless phone
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Homemade Electric Bike Fast Charger
- Circuit diagram explanation: simple switching power supply circuit diagram
Popular Circuits
- STR5412 power circuit
- Laser power circuit
- Diamond differential input power amplifier power circuit
- Single LTC power circuit
- Karaoke light controller circuit (1)
- Music power circuit
- Practical neon light power circuit
- Common power circuits and applications 04
- 6.3V, 270V, 300V DC power supply circuit
- Small power UPS power circuit and production
