Home >
Power Circuits >Switching Regulated Power Supply > Schematic diagram of step-down chopper switching regulated power supply
Source: InternetPublisher:同住地球村 Updated: 2018/05/09
The chopper-type switching regulated power supply is a DC power supply. It obtains a unidirectional square wave through the switching circuit, and then filters it to obtain a stable DC that is different from the input voltage. The so-called buck type means that no matter whether the input voltage Ui is positive or negative, the output voltage Uo is always lower than the input voltage Ui, that is, |Uo|≤|Ui|. The figure is a schematic diagram of a step-down chopper switching regulated power supply. When the switching element VT is controlled to be saturated and turned on, the electric energy is stored in the inductor L and the capacitor C and is also fed to the load. When the switching element VT is controlled to be in the off state, the energy stored in the inductor and capacitor continues to be supplied to the load, and the diode VD forms a current loop. Because the switching element VT and the load resistor RL are connected in series, it is also called a series switching regulated power supply.
Assume that the on-time of the adjustment switch is ton, the load-dead time is toff, and the adjustment switch and the choke inductor are ideal components.
If the adjustment switch element VT is always on and the cut-off time is zero, then Uo=Ui; if VT is always on Cut off, the conduction time is zero, then Uo=0V. With the different ratios of ton and toff, the output voltage Uo is various values between O and Ui.
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/e5138f24-3c63-11ec-8365-086126841eb8.jpg)
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/e5142b66-3c63-11ec-aef5-086126841eb8.jpg)
Latest Power Circuits Circuits
- Schematic diagram of car cigarette lighter to USB power port
- 220V Remote Load Monitor
- Using Lead-acid Battery as Power Source for Walkman
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- ISO113 circuit that can reduce power consumption
- Recommended circuits for different power on times of LM4911
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Detailed explanation of 5v charger circuit diagram
- Power supply circuit that can reduce LM317 ripple
Popular Circuits
- STR5412 power circuit
- Laser power circuit
- Diamond differential input power amplifier power circuit
- Single LTC power circuit
- Karaoke light controller circuit (1)
- Music power circuit
- Practical neon light power circuit
- Common power circuits and applications 04
- 6.3V, 270V, 300V DC power supply circuit
- Small power UPS power circuit and production
