Home >
Power Circuits >Switching Regulated Power Supply > Principle diagram of polarity conversion chopper type switching regulated power supply
Source: InternetPublisher:sigma Updated: 2012/07/19
As the name suggests, the polarity of the output voltage of the polarity conversion power supply is opposite to that of the input voltage, but this is only one aspect of the problem. The absolute value of the output voltage must be higher than the absolute value of the input voltage, otherwise it will be different from the buck switch. Power supply confusion. It is not difficult to see from this that the variable polarity chopper switching power supply is a combination of the above-mentioned buck and boost power supplies. The figure is the schematic diagram of the polarity conversion chopper type switching regulated power supply. When the switching adjustment component transistor VT is turned on, the input voltage Ui is added to L, generating current and storing energy, and the diode VD is reversely blocked. When the transistor VT is turned off, the current in the inductor L gradually decreases, and the polarity of the induced electromotive force is as shown in the figure. This induced electromotive force turns on the diode VD and charges the capacitor C. The output voltage Uo on the capacitor C has the opposite polarity to the input voltage Ui. When the voltage on the load is about to drop, capacitor C discharges the load again. At this time, the output voltage Uo can be higher than the input voltage Ui.
![极性变换式斩波型开关稳压电源原理图](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/e540451c-3c63-11ec-9194-086126841eb8.jpg)
Latest Power Circuits Circuits
- How about the boost converter TPS61299?
- Step-down power supply for driving relays
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- LED Driver ZD1680
- Miniature polarity reversal power supply using MAX1721
- Integrated regulated power supply with continuously adjustable output voltage
- CNC regulated power supply production
- Battery powered switching circuit diagram
- How to Select Modular EMI Filters for AC-DC Converters
Popular Circuits
- STR5412 power circuit
- Laser power circuit
- Diamond differential input power amplifier power circuit
- Single LTC power circuit
- Karaoke light controller circuit (1)
- Music power circuit
- Practical neon light power circuit
- Common power circuits and applications 04
- 6.3V, 270V, 300V DC power supply circuit
- Small power UPS power circuit and production
