Home >
Power Circuits >Switching Regulated Power Supply > Practical circuit of full-bridge switching regulated power supply
Source: InternetPublisher:风向西瓜 Updated: 2019/12/31
The picture shows a practical circuit of a full-bridge switching regulated power supply. It is a 1500W bipolar power tube switching regulated power supply circuit controlled by CW494. In the circuit, four bipolar high reverse voltage transistors F661 are used as switching tubes. Under the control of the integrated circuit CW494, the two pairs of tubes are alternately turned on and off to convert the direct current into high-frequency alternating current, which is then stepped down by the high-frequency transformer. , through rectification and filtering, a stable DC voltage of 12V is obtained. The BVceo of the F661 power switch tube is ≥400V, and the tooff time is 1μs, so under high-power working conditions, its power loss is small.
High-frequency transformer T1 is the core component of the circuit. Its magnetic properties have high requirements: the frequency characteristics must reach MHz; the saturation magnetic flux density must reach 5 000Gs; the hysteresis loss must be small; when using EC70 core, the output power can reach 1000W; when using EC90 core. The output power can reach 2000W.
![全桥式开关稳压电源实用电路](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/e78dc02e-3c63-11ec-961a-086126841eb8.jpg)
Latest Power Circuits Circuits
- Fabrication of multi-cell lithium battery charging circuit
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- What kind of circuit is a voltage regulator circuit?
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Recommended circuits for different power on times of LM4911
- Driving circuit that controls LED brightness using PWM signal
- Constant current LED lamp driver circuit with soft start and anti-shock
- LNK304 non-isolated LED light string driver circuit
- Miniature polarity reversal power supply using MAX1721
- Adjustable voltage regulated power supply circuit
Popular Circuits
- Excellent performance household inverter power supply circuit
- Output 12V-10A power supply circuit
- Single phase thyristor slotless nickel plated power circuit
- Warm current power circuit a
- Household emergency power circuit 02
- Common power circuits and applications 08
- Common power circuits and applications 03
- DC-DC conversion power supply circuit
- ±5V, ±12V power circuit A
