Lithium battery fast charger circuit diagram design
Source: InternetPublisher:两手空空 Keywords: Power battery circuit Updated: 2021/03/18
![Lithium battery fast charger circuit diagram design](http://www.eeworld.com.cn/circuit/upload/829856bd51c3996399e7665925031dbd/126c880d618d6d8eeeec31b0bad9a07a.gif)
Circuit principle: This circuit has a charging status display function. The red light flashes and is charging, the green light flashes and is about to be fully charged, and the green light illuminates and is fully charged. As long as you have a 12V power supply, don't install the battery after connecting the circuit. Adjust the adjustable resistor in the lower right corner so that the battery output is 4.2V. Then adjust the adjustable resistor in the lower left corner so that the third pin of LM358 is 0.16V. That's it, the charging current is 380mA. The three parallel-connected diodes are step-down to prevent the LM317 from overheating, and a heat sink must be added to the LM317. The triode in the picture can be of any type.
- 220V Remote Load Monitor
- Using Lead-acid Battery as Power Source for Walkman
- Fabrication of multi-cell lithium battery charging circuit
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Detailed explanation of 5v charger circuit diagram
- A novel and practical DC low voltage stabilized power supply
- UC3842 Electric Vehicle Charger
- Production of backup power supply for cordless phone
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Homemade home inverter circuit diagram
- CMOS touch circuit
- Nickel cadmium battery remote control
- Portable device charging power circuit design
- Solar power circuit
- FGDF-3 three-phase low-temperature iron-plated power supply circuit
- Remote control TV doorbell power circuit
- Head amplifier dedicated power supply circuit
- Neon light high voltage power supply circuit
- Common power circuits and applications 06
