CNC constant current source circuit diagram for battery charging
Source: InternetPublisher:抄写员 Keywords: Comprehensive power supply battery CNC constant current source Updated: 2021/02/13
This picture is a numerically controlled constant current source designed to charge the battery. The D/A converter outputs a voltage value to the non-inverting terminal of the lower op amp. The current in the circuit is I=Uad/sampling resistor. The two PORTs are used to connect the + and - poles of the battery. The above operational amplifier is connected to an amplification circuit with an amplification factor of 1/4. Used to measure battery voltage. The two adjustment tubes in the picture are 3dd13 and 3dd15 respectively.
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Basic connection circuit of signal and power supply composed of ISOll3
- LED Driver ZD1680
- A simple positive and negative power supply circuit
- Power supply circuit that can reduce LM317 ripple
- Converting a lithium battery charging board into a constant voltage and current charger
- Car Audio Power Supply
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- The production of adjustable voltage-stabilized power supply composed of LM317
- Detailed explanation of mobile phone charger circuit diagram
- Dual adjustable power circuit
- Typical Reference Voltage and Power Supply Circuits
- High current (4A) switching regulator integrated circuit L296 outputs 5.1 to 40V
- Additional power circuit design for USB devices
- Remote control TV doorbell power circuit
- Music power circuit
- Power circuit for home appliance repair
- Wide input 350mA LED driver circuit based on NCL30000
- Common power circuits and applications 07
- AC-DC conversion power supply-inverter power supply circuit
