Switching power supply high withstand voltage constant current source circuit diagram
Source: InternetPublisher:红水杯 Keywords: Switching power supply constant current source power supply constant current source high withstand voltage Updated: 2021/07/03
To develop the instrument, we need a constant current source that can generate 1MA current on a resistance of 0 to 3 megohms. We designed one using UC3845 combined with a 12V battery. The transformer used a color TV high-voltage package, in which L1 was wound with 24 turns of enameled wire on the core of the original high-voltage package. , L3 uses a coil of the original high-voltage package, and L2 uses the high-voltage part of the high-voltage package. L3 and LM393 form a voltage limiting circuit to limit the output voltage from being too high. Adjusting R10 can adjust the open circuit output voltage.
- How about the boost converter TPS61299?
- Using Lead-acid Battery as Power Source for Walkman
- What kind of circuit is a voltage regulator circuit?
- Basic circuit description of adjustable voltage regulator LM317
- Constant current LED lamp driver circuit with soft start and anti-shock
- LNK304 non-isolated LED light string driver circuit
- A small and easy-to-make fast charger
- UC3842 Electric Vehicle Charger
- Practical constant current charger-----Constant current charger
- Homemade Electric Bike Fast Charger
- Worth-seeing Engineer’s Power Supply Design Experience
- LED drive circuit based on switching power supply
- Current source type three-phase PWM rectifier circuit
- Switching power supply circuit composition and detailed explanation of each part (2)
- Self-switching power supply
- Low power consumption induction cooker switching power supply module
- Internal cubic block diagram of switching power supply integrated circuit 5M0269R
- Parallel switching power supply for televisions (b)
- Application of TDK high-power field effect tube full-bridge components in switching power supplies and class D amplifiers 03
- Switching power supply starting circuit diagram using triode
