Current source type three-phase PWM rectifier circuit
Source: InternetPublisher:aerobotics Keywords: Switching power supply current source three-phase pwm rectifier circuit Updated: 2020/03/26
The output of the current source type three-phase PWM rectifier has DC current source characteristics, and uses the sinusoidal modulation method to control the distribution of the DC current I i in each switching device.
Make the AC current waveform close to a sine wave and in the same phase as the power supply voltage. The function of the AC side capacitor is to filter out high-order harmonics related to the switching frequency.
The advantages of current source rectifiers are:
① Due to the existence of the output inductor, it does not have the problems of bridge arm direct current flow and output short circuit;
② The switching device directly pulse-width modulates the DC current, so its input current control is simple and the control speed is fast.
weakness is:
① The rectifier output inductor has large volume, weight and loss;
② Commonly used full-control devices are bidirectionally conductive, and the main circuit configuration is inconvenient and the conduction loss is large.
![Current source type three-phase PWM rectifier circuit](http://www.eeworld.com.cn/circuit/upload/cdbdb8bfd5819dcf15f66e8c3deef163/2f7593fcaa0f897a59020919ba98151f.jpg)
- Practical and convenient fax machine power supply control circuit
- Energy-saving motorcycle rectifier regulator
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Transformerless AC-DC constant current LED driver circuit
- Dual forward converter schematic diagram
- A simple positive and negative power supply circuit
- Design of electric vehicle charger
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- A low-cost, high-reliability battery charger for electric vehicles
- Homemade home inverter circuit diagram
- Working principle diagram of a household switching power supply
- Switching power supply driver PM4040F application circuit diagram
- Low power consumption induction cooker switching power supply module
- Internal cubic block diagram of switching power supply integrated circuit 5M0269R
- Switching power supply constant current charger circuit diagram
- Application of TDK high-power field effect tube full-bridge components in switching power supplies and class D amplifiers 03
- High-fidelity power amplifier using switching power supply 01
- Switching power supply high voltage constant current source circuit diagram
- Switching power supply output part circuit diagram
- Three-terminal PWM switching power supply-PWR-TOP200 series and applications 04
