Lithium battery fast charger circuit diagram design
Source: InternetPublisher:常思一二 Keywords: Fast charger power charging circuit circuit diagram lithium battery Updated: 2021/03/21
![Lithium battery fast charger circuit diagram design](http://www.eeworld.com.cn/circuit/upload/8ba90301d0abaa8ca5499c3645a73406/7c91df07926c0a3a9010b9c5c9d0d1fb.jpg)
Circuit principle: This circuit has a charging status display function. The red light flashes and is charging, the green light flashes and is about to be fully charged, and the green light illuminates and is fully charged. As long as you have a 12V power supply, don't install the battery after connecting the circuit. Adjust the adjustable resistor in the lower right corner so that the battery output is 4.2V. Then adjust the adjustable resistor in the lower left corner so that the third pin of LM358 is 0.16V. That's it, the charging current is 380mA. The three parallel-connected diodes are step-down to prevent the LM317 from overheating, and a heat sink must be added to the LM317. The triode in the picture can be of any type.
- Sharing layout and tips for multi-rail power supply design
- 220V Remote Load Monitor
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Basic connection circuit of signal and power supply composed of ISOll3
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Simple and practical LED lamp driving circuit
- How to use SBR to improve power conversion efficiency
- Miniature polarity reversal power supply using MAX1721
- Dual forward converter schematic diagram
- MAX1811 Lithium Battery Charger Production
- variable gain amplifier
- Car battery charging circuit diagram
- Power supply circuit design optimized for digital light projectors
- Industrial product promotion and shopping guide DC power supply circuit
- High current (4A) switching regulator integrated circuit L296 outputs 5.1 to 40V
- Nickel-cadmium battery fast charger circuit diagram
- Fast charger circuit diagram using BQ2002 integrated chip
- Walkie-talkie fast charger
- Pulse fast charger
- Negative voltage slope fast charger
