Drive circuit (voltage type)
Source: InternetPublisher:小胖友 Updated: 2016/09/14
The drive circuit shown in (a) is suitable for low-frequency and low-power driving. When the control signal Ui is high level, VT1 is turned on, and the switch tube (IGBT) corresponding to the output voltage Uo is turned on; when the control signal Ui is low level , VT2 is turned on, and the switching tube (IGBT) controlled by the output voltage Uo is turned off. The drive circuit shown in (b) is a push-pull circuit composed of field effect transistors, and its working principle is the same as the circuit shown in (a). The high-frequency peak drive current of this circuit can reach more than 10A, and is suitable for high-power IGBT devices.
Latest Power Circuits Circuits
- 5 Converter Topologies for Integrated Solar and Storage Systems
- A very convenient small power supply circuit to share
- Step-down power supply for driving relays
- Use pulse width modulation to get a precise output voltage
- LED Driver ZD1680
- Low cost and high performance LED constant current power supply
- Charging control circuit made by solar energy
- A novel and practical DC low voltage stabilized power supply
- Integrated regulated power supply with continuously adjustable output voltage
- Circuit diagram explanation: simple switching power supply circuit diagram
Popular Circuits
- STR5412 power circuit
- Laser power circuit
- Diamond differential input power amplifier power circuit
- Single LTC power circuit
- Karaoke light controller circuit (1)
- Music power circuit
- Practical neon light power circuit
- Common power circuits and applications 04
- 6.3V, 270V, 300V DC power supply circuit
- Small power UPS power circuit and production
