LA4287 sound circuit
Source: InternetPublisher:司马缸砸光 Updated: 2019/01/18
Relevant key device information applied in this article:
LA4287
TV audio signal is input from pin (1) of N601, AV audio signal is input from pin (3) of N601, and the TV/AV switching signal output by CPU (40) pin is passed through R601 Sent to the base of V601, V601 inverts the phase and controls the (4) pin of N601. After internal selection, the audio signal is output from the (9) pin of N601 to push the speaker to sound. V641 and V642 form a shutdown sound squelch circuit: when the machine is turned on normally, the 12V voltage is added to the base of V641 through R641, and then added to the emitter of V641 through VD642. Due to the presence of VD642, the base voltage of V641 is higher than the emitter voltage. When the voltage is 0.7V higher, V641 is cut off, and V642 is also cut off. This circuit has no effect on the volume control. At this time, C641 is charged with a voltage of nearly 12V. When the power is turned off, the 12V voltage disappears. At this time, because C641 is charged with 12V voltage, the base voltage of V641 is lower than the emitter voltage. V641 is turned on, V642 is also turned on, and the volume control voltage is short-circuited to ground, achieving shutdown silence. noise. LA4287 pin functions and reference voltage: Pin 1: 6.3V - Signal input 1 Pin 2: 0V - Ground Pin 3: 6.3V - Signal input 2 Pin 4: 2.1V - Signal switch Pin 5: 0.67V - Volume control voltage input pin 6: 9.8V - Filter pin 7: 9.8V - Feedback pin 8: 0V - Ground pin 9: 9.9V - Output pin 10: 21V - Power supply
Latest Remote Control Circuits Circuits
- Wireless remote doorbell
- Production of single channel remote control switch
- Infrared receiver made with CD4040
- Long-distance infrared emission circuit diagram analysis
- Remote control receiving and decoding component TH9738
- How the infrared remote control mouse works
- Color TV remote control 21
- Fifteen-channel wireless anti-theft alarm system (FDD5/JDD5)
- SB-50ALTX receiver
- Wireless remote control/touch switch circuit
Popular Circuits
- Infrared remote control electric fan circuit diagram
- Remote control circuit diagram composed of CSJ-T300B and CSJ-R02B
- Sub-ultrasonic remote control circuit
- Remote control circuit b composed of RX5019 and RX5020
- Remote control circuit b composed of TDC1808
- Radio wireless remote control circuit a
- Photoelectric conversion remote control circuit of glass bottle counter
- High frequency remote control circuit design circuit diagram
- Servo mechanism position remote control circuit diagram
- Practical DTMF encoding and decoding wireless remote control circuit
