Photoelectric conversion remote control circuit of glass bottle counter
Source: InternetPublisher:拿铁三分糖 Keywords: Counter remote control circuit photoelectric conversion BSP Updated: 2020/01/20
(1) Working principle of the circuit When counting glass bottles on the conveyor belt. First, the running glass bottles should be converted into pulse signals, and then
the pulse signals (one pulse for each bottle) should be sent to the counter for automatic counting. The circuit shown in Figure 7-17 is a photoelectric conversion
circuit
for a glass bottle counter .
When there is no glass bottle on the belt, the photosensitive
musk tube 3DU has low resistance when exposed to direct light, and the photocurrent
burns; 'Vr'1 is cut off, which is resistant to VT2 saturation. .
VT3 cut off. At the moment when the glass bottle blocks light,
the phototransistor shows high resistance. lb. increases, VT1 is saturated
, and Ucl drops from +5v to o. This negative jump
is differentiated by RC to obtain a negative pulse, which triggers
the monostable circuit, causing 1rF2 to cut off and VT3 to
conduct. The monostable circuit automatically returns
to the original state after a period of time and obtains a wider pulse, which
avoids
the phenomenon of multiple signals caused by one bottle due to flash, etc.
YF1-YF5 form an integral shaping circuit, which is also a monostable circuit. It can narrow the above-mentioned wider pulses to meet the counting
requirements.
Because the glass bottle is transparent, the photocurrent and dark current of the photoelectric tube change in a wider range. Small, in order to make VT1 reliably saturated and cut off. ,
adjust the potentiometer RP carefully and repeatedly .
(2) Component selection VT1~VT3 all use 3DG6.3>50 transistors. YF1-YF5 choose 74Lsoo type integrated circuit "NAND"
gate. Ruler and R. The value of t should be determined according to the shading time of each bottle, which can be calculated according to CR =2r (f is the shading time). Other component type female
parameters
- Battery equalization system and control method thereof
- LJ2 series transistor proximity switch principle circuit diagram
- One control two constant pressure water supply frequency conversion speed control circuit b
- XDH-2 electrocardiograph circuit
- One of the cooling fan automatic control circuits
- EKG FM Demodulator Circuit
- Remote control fan speed regulator circuit
- "Happy New Year" ring game console circuit
- CNC machine tool display circuit
- Electronic ventriloquist circuit
- Electronic thermometer circuit
- Egg warming circuit
- Varactor Diode Frequency Modulator
- collector amplitude modulation circuit
- Amplitude modulation circuit composed of MC1496
- Differential Amplifier Circuit
- Voltage series negative feedback amplifier circuit
- Three primary color display circuit
- Small current generator circuit
- Sine wave signal generator circuit
