Long-distance infrared emission circuit diagram analysis
Source: InternetPublisher:明天见 Keywords: MOSFET infrared emitter Updated: 2023/12/26
Here's the long range/long range IR transmitter circuit to provide extra power to your IR transmitter. Most infrared remote controls do the job reliably within a range of 5 meters. If you design your IR transmitter to operate well over extended distances (e.g. 10 meters), the circuit complexity increases. To double the distance from 5 meters to 10 meters, it is recommended to increase the transmit power by 4 times.
If you want to achieve a highly directional infrared beam (a very narrow beam), you can appropriately use an infrared laser pointer as the infrared signal source. Laser pointers are easily available in the market. Even so, with the very narrow beam emitted by a laser pointer, you still need to be particularly careful lest a slight shake of the gadget might alter the beam positioning and cause loss of contact. Here's a really simple circuit that will get you quite a distance. It utilizes three infrared emitting LEDs (IR1 to IR3) connected in series to increase the radiated power. Additionally, to increase directionality and power density, you can build an IRLED inside the flashlight's reflector.
To improve the performance of the circuit, a MOSFET (BS170) is used, which operates as a switch, thus minimizing the electrical power losses that can occur when using transistors. To prevent any dips during its "on"/"off" operation, a 100uF storage capacitor C2 is used across the battery supply. If the infrared transmitter is powered by ordinary batteries, its benefits will be more obvious. Capacitor C2 provides additional charge during the "turn on" process.
Since MOSFETs exhibit a large capacitance between the gate-source terminals, a specific driver arrangement has been built implementing an NPN-PNP Darlington pair of BC547 and BC557 (as an emitter follower) to Prevent gate drive input distortion. The data used for transmission (CMOS compatible) is used to modulate the 38kHz frequency generated by the CD4047 (IC1). Even so, in the circuit shown here, tactile switch S1 has been used to modulate and transmit the IR signal.
Assemble the circuit on a standard PCB. Use switch S2 for power "on"/"off" control. Commercially available IR receiver modules (e.g., TSOP1738) can be used to efficiently receive the transmitted IR signal.
- Dual motor wireless remote control circuit production
- Simple infrared remote control light switch circuit
- Infrared detection switch circuit
- Long-distance infrared emission circuit diagram analysis
- Anti-theft high voltage password box
- Infrared remote control multi-channel relay control switch circuit
- Ceiling fan wireless remote control circuit
- Control of car central door lock and starting system
- Remote doorbell that can identify the owner
- Add scheduled do not disturb function to the phone
- Simple and practical remote control detector circuit diagram
- Household advance working remote control circuit-receiving circuit
- Telephone remote control circuit
- Car window control circuit
- UC3625 brushless DC motor open loop speed control
- Quad infrared transmitter circuit
- LB1475 (video recorder) two-wire wired remote control circuit
- Simple infrared transmitter circuit with small battery consumption
- Telephone DTMF remote control circuit diagram
- GM3044 type CMOS remote control infrared transmitter circuit
