Home >
Control Circuits >Motor Control > Capacitor-started single-phase motor non-frequent commutation circuit
Source: InternetPublisher:闪电杰克 Updated: 2017/01/17
The resistance values of the main winding LR and the secondary winding LA of this kind of motor are not equal. If measured with a multimeter, the winding with a smaller resistance value and not in series with the capacitor C is the main winding LR, which has a larger resistance value and is connected in series with the capacitor C. is the secondary winding LA. The working principle is shown in the figure. In the figure, C is the starting capacitor of the secondary winding, usually 1μF, and SA is the double-pole double-throw toggle switch KN3-3-2×2. When the motor is used as an exhaust fan, throw the SA to the "positive" position, the motor will rotate forward, and the exhaust fan will exhaust air to the outdoors; when the SA is thrown to the "reverse" position, it will rotate in the reverse direction, and the exhaust fan will send air to the room. Since the toggle switch SA only has two-way double throw and no neutral (stop), an additional power switch S is installed in the circuit.
![电容启动式单相电动机非频繁换向电路](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/4f6f5fb0-3c64-11ec-8bbc-086126841eb8.jpg)
Latest Control Circuits Circuits
- Servo motor pin diagram/working principle/application
- Build a Smart Garage Door Opener Using a Raspberry Pi
- How to Make a Simple Chicken Incubator
- DC motor drive circuit composed of L293D
- Squirrel cage asynchronous motor reverse braking control circuit
- Temperature control circuit design and analysis
- Simple three-phase motor phase loss protection circuit
- Magnetic door and window anti-theft alarm
- Guanghua brand anti-theft doorbell electronic lock circuit
- Water supply reminder after water outage
Popular Circuits
- fire smoke control circuit
- Mobile phone camera flash control circuit
- Switching regulated power supply circuit
- Water dispenser double sheet control circuit
- Assembly line outage monitoring circuit
- 24h automatic switching capacitor control circuit
- Digital current loop control circuit
- Relay control circuitb
- Forward and reverse control circuit of micro DC motor a
- Power supply circuit with multiple outputs (MAX1902)
