Home >
Control Circuits >Motor Control > Three-phase motor automatic time-limited commutation circuit
Source: InternetPublisher:elleny Updated: 2012/06/28
As shown in the figure, KT1 and KT2 are time relays. After closing the main switch QS, K1 pulls in, KMF pulls in, the motor rotates forward, and KT1 starts timing. When KT1 reaches the timing, it automatically disconnects, the K1 coil loses power, KMF is released, and the motor stops; at the same time, the normally open contact of KT1 closes, the coil K2 pulls in, the KMR coil receives power, the motor reverses, and KT2 starts timing. . When the KT2 timer arrives, its normally closed contact KT2 is disconnected, the K2 coil loses power, KMR is released, and the motor stops. The loss of power of K2 causes its normally closed contact to return to the normally closed state, KT1 and K1 work, and the motor enters forward rotation. Afterwards, the process is the same as mentioned above, starting over and over again, so that the three-phase motor enters the automatic limited time cycle working state.
![三相电动机自动限时换向电路](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/4f7f175c-3c64-11ec-b08d-086126841eb8.jpg)
Latest Control Circuits Circuits
- How to use a microcontroller to control a servo motor?
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- Perform surgery on the speaker protection circuit
- Motor automatic cycle control circuit
- Methods for Eliminating Noise of Brushed DC Motors
- Starting method of asynchronous motor with external frequency-sensitive resistor
- One-way rotation circuit of motor controlled by contactor
- Design and analysis of the principle of automatic power-off switch during power outage
- Design and production of wireless multi-location control switch circuit
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
Popular Circuits
- fire smoke control circuit
- Mobile phone camera flash control circuit
- Switching regulated power supply circuit
- Water dispenser double sheet control circuit
- Assembly line outage monitoring circuit
- 24h automatic switching capacitor control circuit
- Digital current loop control circuit
- Relay control circuitb
- Forward and reverse control circuit of micro DC motor a
- Power supply circuit with multiple outputs (MAX1902)
