Home >
Control Circuits >Motor Control > Frequency-sensitive resistor started wound rotor asynchronous motor manual commutation circuit
Source: InternetPublisher:公子李 Updated: 2016/01/21
The picture shows a manual reversible starting circuit. Press the forward start button STF, and the other pair of normally closed contacts of STF are disconnected, cutting off the circuit of the reverse coil KMR. At this time, the forward coil KMF is attracted, and the wound rotor motor is connected in series with the frequency-sensitive resistor L, entering In the starting state, its speed gradually increases. When the speed rises to about 70% of the rated speed, when the run button SN is pressed, KM3 absorbs and protects itself, the frequency-sensitive resistor is short-circuited, and the motor enters full voltage operation. When the work is completed, press STP and stop the vehicle. In the same way, when the STR button is pressed, the motor enters reverse start, and when SN is pressed, the motor enters full voltage operation.
![频敏电阻启动式绕线转子异步电动机手动换向电路](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/4fc17886-3c64-11ec-a1c2-086126841eb8.jpg)
Latest Control Circuits Circuits
- How to choose the right level of integration to meet motor design requirements?
- Car ice warning circuit sharing
- How can we make the robot move precisely on a predefined path?
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- How to set up a cheap beam break sensor control distance scene using a reflector
- Simple phase failure protection circuit composed of intermediate relay
- Design and production of radio remote control fan stepless speed regulator
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- A novel and practical power line anti-theft and cutting alarm circuit
- Precious home appliance anti-theft alarm
Popular Circuits
- fire smoke control circuit
- Mobile phone camera flash control circuit
- Switching regulated power supply circuit
- Water dispenser double sheet control circuit
- Assembly line outage monitoring circuit
- 24h automatic switching capacitor control circuit
- Digital current loop control circuit
- Relay control circuitb
- Forward and reverse control circuit of micro DC motor a
- Power supply circuit with multiple outputs (MAX1902)
