Three-phase motor button interlock commutation circuit
Source: InternetPublisher:蓝猫淘气 Updated: 2012/06/21
The picture shows the button interlock commutation circuit of a three-phase motor. This circuit uses a composite button (that is, there is a pair of normally open contacts and a pair of normally closed contacts in one button, which act simultaneously when the button is pressed) to realize button interlocking connection. When the motor is running in the forward direction, pressing the STR button will immediately cause the KMF to lose power, stop the motor, and immediately enter reverse operation. vice versa. This not only ensures that the forward and reverse contactors KMF and KMR will not be energized at the same time, but also allows you to directly press the reverse button to start the reverse without pressing the stop button.
![三相电动机按钮联锁换向电路](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/51a7cbd4-3c64-11ec-9338-086126841eb8.jpg)
Latest Control Circuits Circuits
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Peripheral circuit of automotive motor controller power supply chip
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- A small improvement to the temperature and water level indicator alarm
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Ultra-short wave item left behind reminder alarm
- Bicycle anti-theft alarm
Popular Circuits
- fire smoke control circuit
- Mobile phone camera flash control circuit
- Switching regulated power supply circuit
- Water dispenser double sheet control circuit
- Assembly line outage monitoring circuit
- 24h automatic switching capacitor control circuit
- Digital current loop control circuit
- Relay control circuitb
- Forward and reverse control circuit of micro DC motor a
- Power supply circuit with multiple outputs (MAX1902)
