Home >
Control Circuits >Motor Control > Commutation circuit controlled by KO-3 three-phase switch for single-phase motor
Source: InternetPublisher:aytwartoofyoroo Updated: 2016/05/06
As shown in the figure, the ordinary three-phase motor reversing switch type KO-3 is modified and can be used to control the forward and reverse rotation of a single-phase capacitor starter motor. During modification, use one wire to connect terminals 1 and 5, use two wires to connect 4 and 6 to the power supply respectively; lead 4 wires from terminals 5, 8, 9 and 6 respectively and connect them to the capacitor starting single-phase The terminal box of the motor is V(D2), W(D3), V"(D5), W"(D6). It should be noted that the two wires 5 and 6 must be connected to the terminals V(D2) and W"(D6) of the motor. That is, on the main winding coil LR, 8 and 9 are connected to the auxiliary winding LA: the U (D1) and U" (D4) terminals are connected to the terminals of the starting capacitor C; the motor centrifugal switch S is connected to W and U of the terminal box "(D3, D4). Operation method: Push the KO-3 switch handle to "positive", S1 is turned on, and the motor rotates forward; when it is pulled back to the middle position "stop", the motor is powered off; then pull it to " When "reverse", the motor reverses; when pushed back to "stop", the motor stops. It is worth mentioning that when the motor switches from one operating state to another (such as forward rotation to reverse rotation), it must Let the motor stop before starting again, otherwise the starting current required to overcome the rotational inertia of the motor will be extremely large, which is detrimental to both the motor and the switch.
![单相电动机用KO-3型三相开关控制的换向电路](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/52d9c09e-3c64-11ec-92f0-086126841eb8.jpg)
Latest Control Circuits Circuits
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- A simple door handle touch alarm circuit
- Motor automatic cycle control circuit
- One-way rotation circuit of motor controlled by contactor
- Do-it-yourself trial production of phase failure protection device
- Simple three-phase motor phase loss protection circuit
- Audio interface protection circuit
- Magnetic door and window anti-theft alarm
- Water supply reminder after water outage
- Password type motorcycle anti-theft device
Popular Circuits
- fire smoke control circuit
- Mobile phone camera flash control circuit
- Switching regulated power supply circuit
- Water dispenser double sheet control circuit
- Assembly line outage monitoring circuit
- 24h automatic switching capacitor control circuit
- Digital current loop control circuit
- Relay control circuitb
- Forward and reverse control circuit of micro DC motor a
- Power supply circuit with multiple outputs (MAX1902)
