Home >
Control Circuits >Motor Control > Frequency-sensitive resistor started wound rotor asynchronous motor automatic commutation circuit
Source: InternetPublisher:太白金星 Updated: 2018/11/27
As shown in the figure, when the forward start button STF is pressed, the KMF coil is powered on and the motor is started by connecting the frequency-sensitive resistor in series. At the same time, the time relay KT starts timing. When the lKT setting time arrives, its normally open and instantaneous closing contacts act, and the contactor KM is powered to attract and protect itself, and at the same time the KT coil circuit is cut off. The main contact of KM will short-circuit L, and the motor will enter full voltage operation. Press STP to stop the motor. The operating principle of reverse operation is the same as above.
![频敏电阻启动式绕线式转子异步电动机自动换向电路](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/52e66afe-3c64-11ec-a436-086126841eb8.jpg)
Latest Control Circuits Circuits
- How to use a microcontroller to control a servo motor?
- Model rocket launch controller circuit
- How to make a wheeled self-balancing robot using ultrasonic sensors
- A simple door handle touch alarm circuit
- Manual automatic air compressor control circuit
- DC motor drive circuit composed of L293D
- Squirrel cage asynchronous motor reverse braking control circuit
- Hydraulic control circuit design and analysis
- Infrared blocking alarm device
- Ultra-short wave item left behind reminder alarm
Popular Circuits
- Multi-channel patrol detection control circuit a
- Water and electricity saving infrared control circuit
- Photocell amplification control circuit
- Switching regulated power supply circuit
- Assembly line outage monitoring circuit
- sound control circuit
- Relay control circuit a
- Temperature measurement and control circuit
- Typical electronic volume control circuit
- Small signal to large current photoelectric control circuit
