Knife switch directly starts the circuit
Source: InternetPublisher:elleny Updated: 2011/06/29
Knife switches include rubber-covered porcelain-based knife switches, iron-shell knife switches, slate knife switches, etc. It can directly start small motors below 7.5kW, the circuit is as shown in the figure. This type of switch is equipped with a fuse tube or a wiring post for connecting the fuse, so it is easy to replace the fuse. Operation method: When the knife switch is closed, the motor M will rotate; when the knife switch is opened, the motor M will stop. This circuit has a wide range of uses, such as water pumps, rice mills, flour mills and other small machinery.
Latest Control Circuits Circuits
- Design and selection of electric control valve system drive
- Analysis of the working principle of car garage door lights
- Peripheral circuit of automotive motor controller power supply chip
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Simple phase failure protection circuit composed of intermediate relay
- IGBT modules block overcurrent by controlling the gate
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Design and analysis of a four-bit remote control component capable of remote reset
- PIC microcontroller controlled remote anti-theft alarm circuit
- Homemade anti-theft watchdog
Popular Circuits
- fire smoke control circuit
- Mobile phone camera flash control circuit
- Switching regulated power supply circuit
- Water dispenser double sheet control circuit
- Assembly line outage monitoring circuit
- 24h automatic switching capacitor control circuit
- Digital current loop control circuit
- Relay control circuitb
- Forward and reverse control circuit of micro DC motor a
- Power supply circuit with multiple outputs (MAX1902)
