Thermal relay overload protection circuit
Source: InternetPublisher:spectrum Updated: 2018/06/07
Due to frequent operation of production machinery and excessive load, a large current flows through the stator winding of the motor for a long time, and this large current cannot blow the fuse, causing the stator winding of the motor to overheat, and in severe cases, the stator may be burned. winding. The above fault can be avoided by using a thermal relay overload protection circuit, as shown in the figure. FT is a thermal relay connected in series to the main circuit. When the motor M is overloaded, the internal thermal element of the FT generates heat, bending the bimetallic sheet, pushing the normally closed contact of the FT to open, causing the AC contactor KM coil to cut off power, and the main contact KM is disconnected and motor M stops, thus eliminating the failure of overload burning the winding. After the overload fault is eliminated, press the "reset" button of the thermal relay and then press the start button ST, and the motor can start again.
Latest Control Circuits Circuits
- Analysis of the working principle of the sound and light controlled delay switch circuit
- Analysis of the working principle of car garage door lights
- Servo motor pin diagram/working principle/application
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- A small improvement on the ordinary refrigerator motor starting circuit
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Design and production of no-load automatic power-off device for household power supply
- Motorcycle anti-theft device circuit design
- Bicycle anti-theft alarm
Popular Circuits
- Multi-channel patrol detection control circuit a
- Water and electricity saving infrared control circuit
- Photocell amplification control circuit
- Switching regulated power supply circuit
- Assembly line outage monitoring circuit
- sound control circuit
- Relay control circuit a
- Temperature measurement and control circuit
- Typical electronic volume control circuit
- Small signal to large current photoelectric control circuit
