DC motor energy consumption braking circuit
Source: InternetPublisher:常思一二 Updated: 2010/03/17
The circuit is shown in the figure. When braking, press the stop button STP, the DC contactor KM loses power, its normally closed contact KM returns to the closed state, causing the voltage relay KV coil to be electrically activated, and its normally open contact KV closes, causing the DC contactor KMB to be For electric action, connect the braking resistor R and the armature M in parallel. Since the direction of the excitation current has not changed, the torque generated by the motor is braking torque, causing the motor to stop quickly. When the counter electromotive force of the motor M is lower than the release voltage of the voltage relay KV, the contact KV is opened, causing the KMB to lose power and release, completing the braking process.
Latest Control Circuits Circuits
- How to use a microcontroller to control a servo motor?
- How to make a wheeled self-balancing robot using ultrasonic sensors
- Manual automatic air compressor control circuit
- Add one more component to improve the phase failure protection function
- IGBT modules block overcurrent by controlling the gate
- Design and production of wireless multi-location control switch circuit
- Design and production of no-load automatic power-off device for household power supply
- An experimental model of an infrared radio alarm
- Guanghua brand anti-theft doorbell electronic lock circuit
- Water supply reminder after water outage
Popular Circuits
- Multi-channel patrol detection control circuit a
- Water and electricity saving infrared control circuit
- Photocell amplification control circuit
- Switching regulated power supply circuit
- Assembly line outage monitoring circuit
- sound control circuit
- Relay control circuit a
- Temperature measurement and control circuit
- Typical electronic volume control circuit
- Small signal to large current photoelectric control circuit
