Home >
Control Circuits >Motor Control > Use a portable light transformer to dry a damp voltage transformer circuit
Source: InternetPublisher:elleny Updated: 2014/01/24
Once the voltage transformer TV gets damp or water seeps, it will no longer work properly. If combined with the vacuum degassing method and using a portable lamp transformer to energize the winding of the voltage transformer to heat and dry it, the TV insulation resistance can be increased to a qualified value, as shown in the circuit in the figure. The specific method is: first drain the insulating oil of the voltage transformer, and use a vacuum pump to degas, so that the moisture is discharged by the vacuum pump. Then energize the windings 1a to 1x of the voltage transformer TV, heat and dry them, and short-circuit the high-voltage windings A to The low-voltage windings 1a~1x of the TV are connected to the 12V block of the portable light transformer T. Close the knife switch QS and adjust the voltage regulator TA so that the current of the ammeter AP is about 30A. At this time, it should be noted that the winding temperature of the TV should not exceed 80oC. The temperature should be tested every 15 minutes, and the temperature should not rise too fast. It is ready when the insulation resistance value rises to the qualified value.
Latest Control Circuits Circuits
- Use your smartphone to turn on/off the power in your home
- Build a glove-controlled robotic arm
- Tutorial for building a remote-controlled Arduino Air-Boat
- What are the challenges in designing a permanent magnet linear generator?
- Working principle of one Xipu STR soft starter controlling two motors
- Motor control circuit for starting and running without phase loss
- Methods for Eliminating Noise of Brushed DC Motors
- Design and analysis of the principle of automatic power-off switch during power outage
- Do-it-yourself trial production of phase failure protection device
- Simple disconnection burglar alarm
Popular Circuits
- Multi-channel patrol detection control circuit a
- Water and electricity saving infrared control circuit
- Photocell amplification control circuit
- Switching regulated power supply circuit
- Assembly line outage monitoring circuit
- sound control circuit
- Relay control circuit a
- Temperature measurement and control circuit
- Typical electronic volume control circuit
- Small signal to large current photoelectric control circuit
