Simple 2051 microcontroller computer remote control circuit diagram
Source: InternetPublisher:消失的歌 Keywords: computer circuit computer remote control Updated: 2021/02/28
The basic principle of the circuit : collect infrared signals through the infrared receiver. When an infrared signal comes in, the microcontroller AT89C2051 software executes an interrupt and decodes the collected infrared signals, and sends them to the PC from the serial port. The PC software Girder receives the infrared signal from the serial port. characters and then make corresponding command operations according to the definition. For the basic usage of Girder, please see "Building a Super PC Remote Control". Several simple components are used in the circuit to make a serial port power stealing circuit, so that the remote control does not need an external power supply and can be used by plugging it into the serial port. It can be said to be plug and play. After installation, after running Girder, the indicator LED1 will start to flash, indicating that the circuit is working normally. You can use your remote control at this time. When Girder is turned off, the power to the circuit board will be cut off and the indicator light will go out.
- S-Video/PAL Video Converter
- Satellite TV room-to-room reception
- Share a home telephone recorder circuit diagram
- Integrated circuit sampling amplification circuit diagram
- Tube amplifier CS8412+PCM63 classic design (power supply part) circuit diagram
- Tube amplifier TDA1541 parallel circuit diagram
- Galanz WP750B computerized microwave oven circuit diagram
- Monolithic integrated circuit radio
- Amplifier DIR1703+PCM1738 DAC PCB circuit diagram
- Transformer AC contactor DC operation circuit a
- Practical circuit diagram that enables remote wake-up/shutdown
- Simple 2051 microcontroller computer remote control circuit diagram
- Car voice cell phone call reminder circuit diagram
- Car mobile phone charger circuit diagram
- Cell phone detector circuit diagram
- Key debounce circuit diagram
- Philips shaver circuit diagram
- Design and production circuit diagram of wireless FM microphone
- AD7780 electronic scale circuit diagram
