Transistor inverter circuit diagram
Source: InternetPublisher:同住地球村 Keywords: Power supply other power circuits Updated: 2021/02/06
This is an inverter circuit, also called a NOT gate circuit in terms of logic circuits. The RB1 (15K) resistor in the figure is the input resistor. Its lower end is the signal input terminal. It should not be connected to ground, but should be connected to the input signal (see the figure below). The RB2 resistor is the bias resistor. When the input terminal voltage = 0, RB1 and The RB2 voltage divider makes the base voltage of the G2 tube negative, causing the emitter of the G2 tube to be reverse-biased, ensuring that the G2 tube is reliably cut off. When the input terminal voltage is positive (eg = +6V), the divided voltage values of RB1 and RB2 are higher than those of G2 The emitter junction of the tube is forward biased, and the emitter junction is turned on, causing the G2 tube to saturate and conduct. See below:
![Transistor inverter circuit diagram](http://www.eeworld.com.cn/circuit/upload/12892b5c400c8edf7efa8b5872745026/e171e9d65c66518e54e88e40ce78a228.jpg)
What is drawn in the dotted box in the figure is the output circuit of the previous stage, which is connected to the input resistor RB1 of the host circuit. When the G1 tube of the previous stage is turned on, its output voltage = 0, and RB1 and RB2 divide the voltage, causing the base of G2 tube to be reverse biased. , so that G2 is cut off and its output is high voltage. When the front-stage G1 tube is turned off, its output voltage is high voltage (+6V). The voltage is divided by Rco, RB1 and RB2, which forward-biases the base of the G2 tube, causing G2 to conduct, and the output = 0.
- Analysis of the working principle of switching regulator
- Driving circuit of switching power supply field effect tube
- Introduction and principle analysis of switching regulated power supply
- Step-down power supply for driving relays
- Constant current LED lamp driver circuit with soft start and anti-shock
- Dual forward converter schematic diagram
- Charging control circuit made by solar energy
- 3~15V 10A adjustable voltage regulated power supply
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Homemade home inverter circuit diagram
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
