LM317 integrated voltage stabilizing circuit
Source: InternetPublisher:李商隐身 Updated: 2018/03/16
The voltage reference between pins 1 and 2 is 1.25V. To ensure the output performance of the voltage regulator, R1 should be less than 240 ohms. Changing the resistance of R2 can adjust the regulated voltage value. D1, D2 are used to protect LM317.
Uo=(1+R2/R1)*1.25
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Design and selection of electric control valve system drive
- What is a RADAX motor?
- Perform surgery on the speaker protection circuit
- Motor automatic cycle control circuit
- Design and analysis of the principle of automatic power-off switch during power outage
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Delay switch made with LM431
- Homemade anti-theft watchdog
- Vibration anti-theft alarm circuit
- fire smoke control circuit
- Mobile phone camera flash control circuit
- Switching regulated power supply circuit
- Water dispenser double sheet control circuit
- Assembly line outage monitoring circuit
- 24h automatic switching capacitor control circuit
- Digital current loop control circuit
- Relay control circuitb
- Forward and reverse control circuit of micro DC motor a
- Power supply circuit with multiple outputs (MAX1902)
