a watchdog circuit
Source: InternetPublisher:qoistoochee128 Updated: 2013/04/30
As shown in the picture above: When the circuit is working, as long as the reset pulse is given to the CD4060 regularly, it can ensure that Q1 is in the cut-off state, so that the controlled NMOS tube is in the conductive state and supplies power to the processor circuit system.
The advantage of this circuit is that the timing time can be relatively long, a few minutes is no problem, and it can give those systems that require a long time to initialize enough time to initialize. The pulse triggers the dog feeding, and when powered on, a reset pulse is automatically given to the counter through R2, C1, and R3 to ensure that Vout has an output. The circuit cost is also low.
The biggest disadvantage of this circuit is that the pulse requirements for feeding the dog are relatively wide.
If there is anything that can be improved about this circuit, you are welcome to give us your valuable opinions.
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Car ice warning circuit sharing
- Tutorial for building a remote-controlled Arduino Air-Boat
- How to make a wheeled self-balancing robot using ultrasonic sensors
- What are the challenges in designing a permanent magnet linear generator?
- Working principle of one Xipu STR soft starter controlling two motors
- IGBT modules block overcurrent by controlling the gate
- Temperature control circuit design and analysis
- Infrared blocking alarm device
- Precious home appliance anti-theft alarm
- fire smoke control circuit
- Mobile phone camera flash control circuit
- Switching regulated power supply circuit
- Water dispenser double sheet control circuit
- Assembly line outage monitoring circuit
- 24h automatic switching capacitor control circuit
- Digital current loop control circuit
- Relay control circuitb
- Forward and reverse control circuit of micro DC motor a
- Power supply circuit with multiple outputs (MAX1902)
