Field output circuit:TDA8354Q
Source: InternetPublisher:狂妄火龙果 Updated: 2013/09/20
This circuit is taken from Venus D2908F
1 pin: 0.3V——
Pin 2: 7.9V - current feedback input
Pin 3: 8.4V - voltage conversion input
Pin 4: 16V - power supply
Pin 5: 8.4V - voltage output terminal (bottom)
Pin 6: 0V - ground
Pin 7: 48V - power supply
Pin 8: 0V - ground
Pin 9: 8.4V - voltage output terminal (upper)
Pin 10: 16V - power supply
Pin 11: 1.2V——Field push input (-)
Pin 12: 1.2V——Field push input (+)
Pin 13: 2V - compensation resistor input
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- Benefits of Wide Bandgap Technology for Power Converters
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Recommended circuits for different power on times of LM4911
- Principles and precautions of active discharge circuit
- Dual forward converter schematic diagram
- Homemade low-power UPS
- 0.7~24V continuously adjustable current limiting power supply
- Adjustable voltage power socket
- Electric bicycle battery charger circuit
- Excellent performance household inverter power supply circuit
- Output 12V-10A power supply circuit
- Single phase thyristor slotless nickel plated power circuit
- Warm current power circuit a
- Household emergency power circuit 02
- Common power circuits and applications 08
- Common power circuits and applications 03
- DC-DC conversion power supply circuit
- ±5V, ±12V power circuit A
