Implementation of analog circuit PWM
Source: InternetPublisher:笑流年 Updated: 2020/04/27
This picture shows a PWM generation circuit that uses a linear potentiometer (or linear Hall element) on a game controller or model aircraft joystick to control two chassis drive motors. J1 is the socket of the handle, 123 and 456 are the potentiometers in the x and y directions respectively. U1B provides half supply voltage and U1A is the voltage follower. The x and y components are synthesized into voltage signals that control the speed of the two motors of the left and right wheels. In use, let L=(x+1)y/(x+1.4), R=(x-1)y/(x-0.6), and it has good results after testing (the numbers are just units, not voltage values) . The voltage is converted into the corresponding PWM signal through the Schmitt oscillator composed of U1C and U1D, which is used to control the power drive circuit. Taking U1D as an example, R1 and R2 form a Schmitt circuit with hysteresis. The upper and lower thresholds are affected by the input voltage. C1 and R3 form a delay loop, so that the pulse width of the oscillation is controlled by the input voltage. Q1 and Q2 are transistors that form an inverter and provide differential control signals. For the specific oscillation process, please refer to the analysis of the 555 oscillator in the digital circuit textbook.
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Use pulse width modulation to get a precise output voltage
- LED Driver ZD1680
- Detailed explanation of 5v charger circuit diagram
- An ultra-low output voltage regulator
- LM317 regulated power supply
- Car power 1.5V-12V six-speed converter
- Adjustable voltage power socket
- Mc34063 MP3 Switching Charger
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Excellent performance household inverter power supply circuit
- Output 12V-10A power supply circuit
- Single phase thyristor slotless nickel plated power circuit
- Warm current power circuit a
- Household emergency power circuit 02
- Common power circuits and applications 08
- Common power circuits and applications 03
- DC-DC conversion power supply circuit
- ±5V, ±12V power circuit A
