Simple and practical 3-button interlocking electronic switch
Source: InternetPublisher:天天都吃好吃的 Updated: 2010/11/21
The circuit structure is simple. Press any key to open the corresponding circuit and close the other two circuits. Contact jitter does not affect the normal operation of the circuit and has good anti-interference.
If the driving transistor behind is removed, the static power consumption of the circuit is almost zero.
By removing the buttons, it can also be converted to pulse control.
- The basic principles of power supply design. What are the key components of a power supply?
- Benefits of Wide Bandgap Technology for Power Converters
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Driving circuit that controls LED brightness using PWM signal
- Dual forward converter schematic diagram
- A simple positive and negative power supply circuit
- The production of adjustable voltage-stabilized power supply composed of LM317
- Homemade Electric Bike Fast Charger
- Homemade home inverter circuit diagram
- STR5412 power circuit
- Laser power circuit
- Diamond differential input power amplifier power circuit
- Single LTC power circuit
- Karaoke light controller circuit (1)
- Music power circuit
- Practical neon light power circuit
- Common power circuits and applications 04
- 6.3V, 270V, 300V DC power supply circuit
- Small power UPS power circuit and production
