A STM32F103F103 and resistive touch screen interface circuit diagram
Source: InternetPublisher:zht24 Keywords: power display power supply Updated: 2020/11/27
This article introduces you to an STM32F103F103 connected directly to a four-wire resistive touch screen through its own I/O port to realize the touch screen controller function; the main circuit is shown in the figure below:
- Dual Power Supply Circuit Analysis
- Is there any voltage at both ends of the current source? How to determine the direction of the voltage at both ends of the current source
- 5 Converter Topologies for Integrated Solar and Storage Systems
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- In-depth analysis of DC-AC converter inverter
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Switching power supply circuit composition and function introduction of each part
- Current/voltage conversion circuit using current converter
- LT3755 driver LED application circuit diagram
- Blood pressure detector display circuit
- Five-digit LED level indication driver integrated circuit typical circuit
- Simple light-emitting display logic pen circuit
- Ordinary optocoupler isolation circuit
- Positive terminal buck/boost LED constant current drive circuit diagram
- Portable device charging power circuit design
- Solar power circuit
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
