Zero-crossing trigger circuit design based on thyristor
Source: InternetPublisher:笑流年 Keywords: Power supply other power circuits Updated: 2021/08/15
Circuit principle: The zero-crossing synchronization pulse is a pulse at the zero-crossing moment of the 50Hz AC voltage, which can trigger the conduction of the thyristor when the AC voltage sine wave crosses zero. The zero-crossing synchronization pulse is generated by the zero-crossing trigger circuit. A more detailed circuit diagram is shown in the figure. In this figure, the voltage comparator LM311 is used to convert the 50Hz sinusoidal AC voltage into a square wave. The positive edge and negative edge of the square wave are used as the input trigger signals of the two monostable triggers respectively. After the two narrow pulses output by the monostable trigger are mixed by the diode or gate, the process corresponding to the AC 220V mains power can be obtained. Zero sync pulse. On the one hand, this pulse is added to the temperature control circuit as a trigger synchronization pulse for the thyristor, and on the other hand, it is also added to the T0 and T1 terminals of the 8031 as a counting pulse.
![Zero-crossing trigger circuit design based on thyristor](http://www.eeworld.com.cn/circuit/upload/51b17c1e03b261c0e72975fa15617750/4bfbcd3e19a4ccfe5bfc4432a17eb71f.gif)
- Sharing layout and tips for multi-rail power supply design
- Analysis of the working principle of switching regulator
- Build a simple buck-boost regulator and test it on a breadboard
- Driving circuit of switching power supply field effect tube
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Basic connection circuit of signal and power supply composed of ISOll3
- Driving circuit that controls LED brightness using PWM signal
- Constant current LED lamp driver circuit with soft start and anti-shock
- Low cost and high performance LED constant current power supply
- An ultra-low output voltage regulator
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
