Flashing light making circuit diagram
Source: InternetPublisher:明天见 Keywords: Power supplyAC/DC Updated: 2020/09/27
The circuit working principle of the device is shown in the figure. Plug in the power plug CT. Since the normally closed contact j1 of the relay J is closed, the lamp H lights up. And since the normally open contact j2 is open, the ④ pin of LSE outputs a low level. At this time, the transistor VT conducts Pass. After VT is turned on, relay J is excited and closed, contact j1 is opened, H goes out, and contact j2 is closed at the same time, so the output of LSE pin 4 is high level at this time, transistor VT is cut off, relay J is released, and contact j1 It closes again, H lights up, and contact j2 opens again... This cycle works over and over again, causing the light H to flash.
![Flashing light making circuit diagram](http://www.eeworld.com.cn/circuit/upload/19bb65000178f83cfb672a75f19f4be7/3b945262adeb147d6ce61ef7b35b8ef6.jpg)
- Introduction and principle analysis of switching regulated power supply
- Basic circuit description of adjustable voltage regulator LM317
- Basic connection circuit of signal and power supply composed of ISOll3
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- LED Driver ZD1680
- Principles and precautions of active discharge circuit
- A novel and practical DC low voltage stabilized power supply
- 0.7~24V continuously adjustable current limiting power supply
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- LM317T voltage regulation adjustable circuit diagram explanation
- Principle of single live wire power taking circuit
- Commonly used soft start circuits for switching power supplies
- Thyristor-rectifier joint arm module three-phase half-controlled bridge rectifier circuit
- Zero-crossing trigger circuit design based on thyristor
- Power circuit b composed of intelligent thyristor modules
- Typical Reference Voltage and Power Supply Circuits
- FGDF-3 three-phase low-temperature iron-plated power supply circuit
- Warm current power circuit a
- Low voltage adjustable reference power circuit
