Zero-crossing trigger circuit design based on thyristor
Source: InternetPublisher:萌面大虾 Keywords: AC power supply AC/DC Updated: 2020/12/16
Circuit principle: The zero-crossing synchronization pulse is a pulse at the zero-crossing moment of the 50Hz AC voltage, which can trigger the conduction of the thyristor when the AC voltage sine wave crosses zero. The zero-crossing synchronization pulse is generated by the zero-crossing trigger circuit. A more detailed circuit diagram is shown in the figure. In this figure, the voltage comparator LM311 is used to convert the 50Hz sinusoidal AC voltage into a square wave. The positive edge and negative edge of the square wave are used as the input trigger signals of the two monostable triggers respectively. After the two narrow pulses output by the monostable trigger are mixed by the diode or gate, the process corresponding to the AC 220V mains power can be obtained. Zero sync pulse. On the one hand, this pulse is added to the temperature control circuit as a trigger synchronization pulse for the thyristor, and on the other hand, it is also added to the T0 and T1 terminals of the 8031 as a counting pulse.
![Zero-crossing trigger circuit design based on thyristor](http://www.eeworld.com.cn/circuit/upload/ede3808be51ea9fc1ded94de9d3786d9/8d306c62e04748d9b0973a5123056d08.gif)
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- How to Make a Soft Latch Circuit
- 220V Remote Load Monitor
- The constant current source composed of two transistors can drive high power
- Parallel DC regulated power supply circuit diagram
- Current/voltage conversion circuit using current converter
- Miniature polarity reversal power supply using MAX1721
- Integrated regulated power supply with continuously adjustable output voltage
- Mc34063 MP3 Switching Charger
- Detailed explanation of mobile phone charger circuit diagram
- Principle of single live wire power taking circuit
- Light control switch circuit in incandescent lamp
- A RKC XTE-7000 temperature controller circuit diagram
- 60Hz input notch filter circuit
- Zero-crossing trigger circuit diagram based on thyristor
- Interface circuit diagram for controlling AC load
- Simple 1-12V constant current charging circuit diagram
- Laser power circuit
- Commonly used power circuits in printers
- 2-phase CPU power circuit using HIP6301 and HIP6601 chips
