Simple and effective power supply phase loss protection circuit
Source: InternetPublisher:吃掉星星 Keywords: Power supply protection Updated: 2020/10/29
If a three-phase motor runs without a phase for a long time during operation, the motor will be burned due to excessive winding current and heat. If there is a lack of phase when starting, the motor will buzz and not be able to turn the meter, or even heat up and burn out. If you use a cabinet air conditioner with a three-phase power supply, the lack of a phase may also cause the compressor to burn out, which will cause greater economic losses. The circuit introduced in this article can overcome this shortcoming, as shown in the figure.
![Simple and effective power supply phase loss protection circuit](http://www.eeworld.com.cn/circuit/upload/9af9aab5d3d595f6d88220feb48b6bb3/a914cdcf291db2dbc6c508277e2b28d1.jpg)
Circuit composition: Use two relays of the same model (the main contacts should be able to meet the maximum current of the motor, and the coil voltage is 380V) for phase loss protection, and the effect is good. The wiring method is shown in the figure. Connect the main contacts of the two relays in series in the motor power supply circuit. When all three phases are powered, relays J1 and J2 are energized at the same time and close their main contacts to make the circuit safely connected. If phase A or phase B suddenly loses power during operation, relay J1 will lose power and trip. , if phase B or phase C suddenly loses power, relay J2 will lose power and trip, cutting off the power supply. Therefore, if any of the three phases A, B, and C is missing, the power supply to the motor will be cut off, thus playing a protective role.
Component selection: There are no special requirements for the components of this circuit, just select them according to the icons.
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- Visible laser digital control modulation driver
- Use pulse width modulation to get a precise output voltage
- LED rechargeable flashlight circuit diagram
- Parallel DC regulated power supply circuit diagram
- Current/voltage conversion circuit using current converter
- An ultra-low output voltage regulator
- USB power socket using the car battery
- The production of adjustable voltage-stabilized power supply composed of LM317
- MAX1811 Lithium Battery Charger Production
- Importance of Voltage Supervisors and Output Topology Selection
- Asynchronous motor protection circuit composed of photoelectric coupler
- Typical Reference Voltage and Power Supply Circuits
- 3-phase CPU power circuit using HIP6301 and HIP6601 chips
- Recording level power supply circuit
- audio power circuit
- Single LTC power circuit
- Neon light high voltage power supply circuit
- 5V, 7.5V, 48V power circuit
- 6.3V, 270V, 300V DC power supply circuit
