Q5337 wireless FM microphone production circuit diagram
Source: InternetPublisher:明天见 Keywords: RF power and other power circuits Updated: 2021/06/28
As shown in the figure is the Q5337 wireless FM microphone production circuit. This microphone has high speech clarity and several main measures have been taken: the signal output by the MIC is first sent to the BG1 tube for amplification, in which R1 and C1 are additional treble pre-emphasis circuit. C2 and C3 are the input and output coupling capacitors of the BG1 tube. Their values are smaller to attenuate the bass and enhance the mids and highs. The circuit of the diodes D3, D4, C4, and R7 connected in reverse parallel at the output end of the BG1 tube uses the characteristic that the internal resistance becomes smaller when the diode is forward-conducted to limit the amplitude of the strong signal, while the normal intensity signal is not affected. It also has a good suppression effect on howling caused by positive feedback between the microphone and the speaker. After the microphone signal is amplified by BG1, it is added to the varactor inside the IC through L5, and the high-frequency signal is frequency modulated to obtain a larger frequency deviation. C7, C8, C9, and L1 form an FM signal tuning circuit, and its operating frequency is between 88MHz and 108MHz. The high-frequency signal output by the IC's pin 1 is tuned and frequency-selected by L2 and C10, then sent to C11 and then coupled to the BG2 tube for radio frequency amplification (BG2 can use a general UHF tube), and then radiates the FM microphone signal to the space. The whole machine is housed in the casing of a pocket semiconductor radio. The MIC is led out with an 80cm long single-core shielded flexible wire. This microphone lead also serves as a transmitting antenna. The high-frequency signal output by C13 is isolated from the ground by inductor L4 and connected to the outer layer of the shielded wire. The MIC is housed in a suitable latex tube and secured to the latex tube with a tie clip. When in use, clamp the microphone on your chest near your collar, hang the machine on your trouser belt, and spread out the microphone wire to achieve the best emission effect. L1, L2, and L3 use an enameled wire of about ∮0.5mm to wrap 5 times around a round rod with a diameter of 5mm. There is a tap on L2. L4, L5 and L6 can be used with ordinary small color-coded inductors. When debugging, first adjust the tightness of L1 so that the radio can receive the signal emitted by the FM microphone in the FM segment, and then adjust C16 to make the signal stronger. Finally, shorten the radio antenna and adjust L3 to maximize the transmission distance. If a simple field strength meter is used for debugging, the best effect can be achieved.
The frequency of this machine is stable and will not drift after being used for several months after being adjusted once. When I use a 4.5V power supply, there is no directionality within the transmitting-receiving distance of 25 meters. When listening to an FM radio, it feels like an FM radio station. This FM microphone is used for classroom teaching in a large classroom of 250 square meters in my unit. It has been used for 6 years and the effect is very good.
![Q5337 wireless FM microphone production circuit diagram](http://www.eeworld.com.cn/circuit/upload/6dc71d25d9485b9a0632fe0456297c22/1f809937feb762b154d535a6670603eb.jpg)
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- Practical and convenient fax machine power supply control circuit
- Step-down power supply for driving relays
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Switching power supply circuit composition and function introduction of each part
- Boost drive circuit composed of RT8450
- LM317 regulated power supply
- MIC4680 constant current charger
- Production of backup power supply for cordless phone
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Analysis of various forms of packaging structures of LED light-emitting diodes
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Diode selection plays a vital role in circuit design
- Automotive electronic fuel saver circuit diagram and principle
- EMC design component selection and circuit design are critical
- Unit circuit of voltage and current control loop
- op amp mixer
- Ruidike PHS mobile phone RF front-end design circuit diagram
- SC41342 (general) infrared, ultrasonic or radio frequency remote control transmission encoding circuit-02
