A frequency meter circuit diagram composed of CD4046
Source: InternetPublisher:spectrum Keywords: Measurement power supply and other power circuits Updated: 2021/03/12
CD4046 is a general-purpose CMOS phase-locked loop integrated circuit. It is characterized by a wide power supply voltage range (3V-18V), high input impedance (about 100MΩ), and low dynamic power consumption. The power consumption is only 600μW when the center frequency f0 is 10kHz. , is a micro-power device.
The frequency meter uses the needle to indicate the level of the frequency being measured. R1 is composed of a 47k fixed resistor and a 51k potentiometer connected in series. R4, R5 and C4 form a low-pass filter. R3 is connected in series with the meter M and serves as the load of the source follower. R3 is also used to adjust the full-scale current of the meter. There is a large capacitor of 100LF on the meter head, which is used to eliminate the jitter of the meter needle at low frequencies. The measurement range of this frequency meter is 20Hz~1kHz.
The following is a frequency meter circuit diagram composed of CD4046 released by Shenzhen Jieduobang PCB Circuit Board Company.
![A frequency meter circuit diagram composed of CD4046](http://www.eeworld.com.cn/circuit/upload/46ed96f325e0a9a406bec14907f52357/12d5aa00622d96a8f51ca2fe546f7142.jpg)
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- 5 Converter Topologies for Integrated Solar and Storage Systems
- Schematic diagram of car cigarette lighter to USB power port
- 220V Remote Load Monitor
- Low cost and high performance LED constant current power supply
- Design of electric vehicle charger
- Converting a lithium battery charging board into a constant voltage and current charger
- Mc34063 MP3 Switching Charger
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- MAX1811 Lithium Battery Charger Production
- About the real-life application of Silicon Labs’ new isolation smart switch
- Photosensitive automatic dimming desk lamp circuit and principle
- Circuit diagram of using photoelectric coupler to make mobile phone call reminder
- What’s so magical about the main circuit inside the inverter?
- Humidity detection circuit schematic diagram
- Two-channel low-power amplifier circuit
- Detailed explanation of audio preamplifier circuit
- mini stereo amplifier
- About the three-phase power grid measurement interface circuit diagram
- Capacitance measuring instrument circuit
