Capacitive liquid level measurement circuit
Source: InternetPublisher:公子李 Keywords: capacitive liquid level measurement measuring circuit BSP Updated: 2021/07/23
Capacitance/C position IJ quantity is to directly convert changes in material level into changes in electrical parameters, and then convert the electrical parameters into unified electrical signals for transmission,
processing, display, etc. According to different electrical parameters, it can be divided into: resistive type, capacitive type and inductive type, etc. Now the capacitive type will be introduced.
We know that the capacitance of the simplest capacitor
is known from the above formula. Corresponding capacitance sensors can be made by changing d, E or changing A. The capacitive level meter mainly consists of
a capacitive sensor and a measurement circuit .
Capacitive sensors are generally made based on the principle of changing the dielectric constant E. Figure 6-38a and b show the capacitive liquid level sensor and measurement circuit. A cylindrical capacitor is set in
the solution to be measured. When the plate distance d and the area A are fixed, the capacitance is C. It will
change with the dielectric constant E of the medium between the plates . Assume the dielectric constant of the liquid is £, and the dielectric constant of the gas is e2. Generally, E, >ez. When the liquid level rises, the total dielectric constant
increases. Therefore, the capacitance G increases accordingly. On the contrary, when the Rang level decreases, E decreases. c, then decreases. Therefore,
the liquid level in the container can be known by measuring the change in C. Figure 6-38b is the capacitance measurement circuit , and G is the reference arm capacitance. '
- How to Measure Turbidity of Liquids Using Arduino
- 4040 Mobile Phone Electromagnetic Radiation Demonstration Experiment Circuit
- Make a Economical and Practical Rectifier Voltmeter
- Simple and practical motor short circuit tester
- Homemade Metal Detector
- System display circuit of electric bicycle speed and odometer composed of CD4076 and 74LS138
- 3 1/2, 4 1/2 digit intelligent digital voltmeter circuit composed of MAX1492/MAX1494
- Simple and easy to make zero degree detector
- Design of Multi-point Temperature Measurement System Based on DS18B20
- A simple no-load self-stop circuit for welding machines
- Motor forward and reverse control wiring diagram (2)
- Pulse therapy circuit
- Straw returning to field crusher circuit
- DC ammeter
- Proportional frequency discriminator circuit
- Schiller oscillator circuit
- Crabo oscillator circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- common emitter amplifier circuit
- Various signal generator circuits
