charge amplifier circuit
Source: InternetPublisher:桂花蒸 Keywords: charge amplifier amplifier circuit Updated: 2021/05/07
Charge amplifier , which is a better impulse
measurement amplifier. This amplifier is actually a high-gain operational amplifier with deep capacitive negative feedback
. There is almost no shunt at the input of the amplifier, and the charge q only
charges the feedback capacitor CF.
When the capacitive reactance is much smaller than the equivalent impedance of the resistor to the input terminal ,
- Simple and practical EPROM detection circuit
- Homemade simple magnetic material tester
- System display circuit of electric bicycle speed and odometer composed of CD4076 and 74LS138
- Circuit Fault Tracker
- 4-range digital voltmeter circuit using ADD3701
- LM3914 makes car battery detector
- Using a Remote Control to Make a Crystal Oscillator Frequency Tester
- Production of acoustic and optical digital level detector
- DS8 type 100V, 5A mutual inductance three-phase three-wire electric meter wiring
- Differential amplifier circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- High performance antenna amplifier circuite
- Output uses DC coupled 15 to 60W audio amplifier circuit
- 75W power amplifier circuit
- Broadband automatic gain control (AGC) amplifier circuit
- One-channel preamplifier circuit for jukebox
- Peak signal amplifier circuit for detecting pH value and radiation
- Electromechanical Controlled DC Amplifier Circuit
- Simple circuit 5W power amplifier circuit
- 10MHz wideband amplifier circuit with 20dB gain
