Contact resistance measurement circuit
Source: InternetPublisher:containsmachine Keywords: Resistance measurement contact resistance measuring circuit BSP Updated: 2021/07/04
The contact resistance measurement circuit is shown in the figure. It mainly consists of constant current circuit and amplifier circuit. The operational amplifier 1C1 and the transistor VT form a
follower, and the voltage at both ends is equal to the rated stable voltage of the voltage regulator tube VS1. Since the resistance of Ra is fixed, a
constant current flows through Rs. The resistor under test is connected in series between terminals A and B. At the connection point between the resistor under test and the resistor under test, the fractional current is very small, so
the current through the resistor under test and the wind can be regarded as the same. In this way, the voltage between terminals A and B It is only related to the resistance measured at terminals A and B (proportional relationship). The measurement of resistance
is converted into a measurement of voltage. The operational amplifier IC2 and its peripheral resistor-capacitor components form an inverse amplifier, which amplifies the voltage between A and B.
The amplification factor is brother/Rz. c], Cz is the memory capacitor required by IC2. The millivoltmeter is connected to the output of IC2. Measure the output voltage of IC2. Assume
that the output voltage of 102 is Vo and the voltage amplification factor is K. , the rated stable voltage of VD1 is Vw, and the measured resistance is feet. , then there is
/Ct=VwR4Rn/R3RZ
R =Rz Ra V/R4 Vw
in the figure. T, VD3-VD6, 1C3 and other components constitute a DC regulated power supply, which outputs a stable 12V voltage when the measuring instrument uses AC mains power
- A highly sensitive human proximity detector
- System display circuit of electric bicycle speed and odometer composed of CD4076 and 74LS138
- Analysis of valid and fault conditions of differential signals
- 3 1/2, 4 1/2 digit intelligent digital voltmeter circuit composed of MAX1492/MAX1494
- 4-range digital voltmeter circuit using ADD3701
- How to Use a Radio as a Metal Detector
- How to use STM32 to design an alcohol tester
- Application of TDA1514
- A simple no-load self-stop circuit for welding machines
- Differential amplifier circuit
- Set timing circuit when power is on
- Ultrasonic blind pathfinder circuit
- Rice mill circuit
- Biogas concentration detection line
- Diode Balanced Mixer Circuit
- Amplitude modulation circuit composed of MC1496
- Series crystal oscillator
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Differential Amplifier Circuit
- color discrimination circuit
