Three-phase electric energy meter wiring circuit a
Source: InternetPublisher:傻阿乐 Keywords: Three-phase energy meter wiring coil Updated: 2020/12/24
Three-phase circuit active energy meters are used in three-phase three-wire circuits and three-phase four-wire circuits. According to different load requirements, they can be
measured by one meter method, two meter method, or three meter method. Each electric energy meter is composed of a voltage coil and a current coil. The voltage coil and current coil of the first group of components
are connected to U respectively. , and ammeter; the voltage coil and current coil of the second group of components are connected to Uwy and the second ammeter respectively. When wiring
, if
any terminal is connected incorrectly, the aluminum plate will rotate reversely, or even though it rotates forward, the reading will not be equal to the power consumed by the three-phase circuit
. This should be paid special
attention to.
- System display circuit of electric bicycle speed and odometer composed of CD4076 and 74LS138
- Infrared detector
- Fire detector made with photodiode
- Temperature-frequency conversion circuit composed of CD4046
- Making an Induction Electroscope Using CD4069
- A low-cost inductance meter consisting of a single IC
- Digitally controlled operational amplifier gain circuit
- Directly coupled push-pull power amplifier circuit
- Multimeter DC voltage measurement circuit
- A simple no-load self-stop circuit for welding machines
- Temporary power lines
- Radial wiring power supply circuit c
- Automated instruments use filters to resist interference wiring
- Wiring b of PLC input and output terminals
- Lightning protection wiring of phase-shifting capacitor on pole b
- Y, y connected transformer lightning protection wiring
- Roof lightning protection network wiring
- Computer system professional ground wire and dedicated conversion socket wiring
- Wiring a when the leakage protector in the TT system is used for single-phase load
- Three-phase power meter wiring b
