Power factor measurement circuit
Source: InternetPublisher:子丑寅卯 Keywords: Power factor measurement circuit BSP LCOS Updated: 2021/11/11
The active power of the load P=UlcosSo, where
cosp is the power factor. Power factor angle,
XL. -xf. '
rp=arctan—■ir一
and-90'≥cip<90. . If b, c, and d in Figure 6-5 are connected to the circuit as loads respectively
, then
when Z=R, p=o, cO prints one l, which is a resistive load;
when Z=5, tp>0, costp> 0, inductive load;
when Z-mo:, p<0, cosp>0. Customer load.
It can be seen that the size and nature of the power factor are determined by the size and nature of the load parameters.
- Simple and practical EPROM detection circuit
- Balcony intelligent invisible anti-theft net
- Temperature Range Monitoring System
- Digital electronic thermometer using semiconductor diode as temperature sensor
- Design of blood analyzer
- Homemade LED digital display photovoltaic meter
- Design of Multi-point Temperature Measurement System Based on DS18B20
- An electronic load meter using LM324 operational amplifier as the main control device
- Geiger counter circuit diagram
- Typical two-stage low-pass filter circuit
- Set timing circuit when power is on
- Agricultural temperature control circuit
- Fish farming thermostatic control circuit
- Farmland drainage automatic control circuit
- Crabo oscillator circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Voltage-controlled voltage source second-order band-pass filter circuit
- color discrimination circuit
- High and low frequency signal generator circuit
- Small current generator circuit
